주요 콘텐츠로 건너뛰기
Lenovo Touch Y70-70 Battery Replacement
필요한 것
  1. Lenovo Touch Y70-70 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Battery Replacement: 2 단계, 이미지 1/1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to unscrew the three screws holding the battery.
  4. Lenovo Touch Y70-70 Battery Replacement: 4 단계, 이미지 1/1
    • Use the Blunt Tweezers from the Tool Kit to disconnect the battery connections from the motherboard.
    • Remove the battery from the device.
결론
To reassemble your device, follow the instructions on Step 3.
다른 2명이 해당 안내서를 완성하였습니다.
Brandon Munson
회원 가입일: 01/18/18
241 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 12
전체 시간: 1,028
