소개
This guide will solve issues involving a defective battery, such as: Unexpected Shutdown, Laptop not Charging, Laptop Shuts down when Unplugged.
필요한 것
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Use the Blunt Tweezers from the Tool Kit to disconnect the battery connections from the motherboard.
Remove the battery from the device.
To reassemble your device, follow the instructions on Step 3.
다른 2명이 해당 안내서를 완성하였습니다.
