주요 콘텐츠로 건너뛰기
Lenovo Touch Y70-70 Motherboard Replacement
필요한 것
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: 2 단계, 이미지 1/3 Lenovo Touch Y70-70 Motherboard Replacement: 2 단계, 이미지 2/3 Lenovo Touch Y70-70 Motherboard Replacement: 2 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: 3 단계, 이미지 1/2 Lenovo Touch Y70-70 Motherboard Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: 4 단계, 이미지 1/3 Lenovo Touch Y70-70 Motherboard Replacement: 4 단계, 이미지 2/3 Lenovo Touch Y70-70 Motherboard Replacement: 4 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: 5 단계, 이미지 1/2 Lenovo Touch Y70-70 Motherboard Replacement: 5 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: 6 단계, 이미지 1/2 Lenovo Touch Y70-70 Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: 7 단계, 이미지 1/2 Lenovo Touch Y70-70 Motherboard Replacement: 7 단계, 이미지 2/2
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: 8 단계, 이미지 1/3 Lenovo Touch Y70-70 Motherboard Replacement: 8 단계, 이미지 2/3 Lenovo Touch Y70-70 Motherboard Replacement: 8 단계, 이미지 3/3
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
결론
Mohammed Motorwala
회원 가입일: 11/07/19
298 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G5, Harley Fall 2019 IUPUI, Team S2-G5, Harley Fall 2019 회원
IUPUI-HARLEY-F19S2G5
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 1,037
