소개
This guide will help you replace the RAM of your device.
  1. Flip the device so the back is facing you.
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. Use the blue Opening Tool to pry-open the back cover.
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  4. Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick. Remove the first stick and and do the same thing to the second RAM stick.
    • Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick.
    • Remove the first stick and and do the same thing to the second RAM stick.
결론
Ean Hobbs
회원 가입일: 2018년 01월 18일
223 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 47
