주요 콘텐츠로 건너뛰기
Lenovo Vibe Z2 Pro Charging Assembly Replacement
필요한 것
  1. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 1 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 1 단계, 이미지 2/2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 3 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 4 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 4 단계, 이미지 2/2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 5 단계, 이미지 1/1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: 6 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: 6 단계, 이미지 2/2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 7 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 7 단계, 이미지 2/2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 8 단계, 이미지 1/1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 9 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 9 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 9 단계, 이미지 3/3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: 10 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: 10 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: 10 단계, 이미지 3/3
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 11 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 11 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 11 단계, 이미지 3/3
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 12 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 12 단계, 이미지 2/2
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 13 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 13 단계, 이미지 2/2
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 14 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 14 단계, 이미지 2/2
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 15 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 15 단계, 이미지 2/2
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 16 단계, 이미지 1/1
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 17 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 17 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 17 단계, 이미지 3/3
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
  18. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Charging Assembly & Headphone Jack: 18 단계, 이미지 1/1
    • Remove the 3.6 mm Phillips head screws from the charging assembly
  19. Lenovo Vibe Z2 Pro Charging Assembly Replacement: 19 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 19 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: 19 단계, 이미지 3/3
    • Gently peel the flat cable away from the screen
    • Gently lift the charging assembly using a spudger
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bryan Sepulveda
회원 가입일: 09/15/16
547 평판
안내서 3개 작성하였습니다
USF Tampa, Team 18-3, Blackwell Fall 2016 USF Tampa, Team 18-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,006
