주요 콘텐츠로 건너뛰기
Lenovo Vibe Z2 Pro Screen Replacement
필요한 것
  1. Lenovo Vibe Z2 Pro Screen Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 1 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 1 단계, 이미지 2/2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Screen Replacement: 2 단계, 이미지 1/1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Screen Replacement: 3 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement: 3 단계, 이미지 2/2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Screen Replacement: 4 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement: 4 단계, 이미지 2/2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Screen Replacement: 5 단계, 이미지 1/1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Screen Replacement, Battery: 6 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement, Battery: 6 단계, 이미지 2/2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Screen Replacement: 7 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement: 7 단계, 이미지 2/2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Screen Replacement: 8 단계, 이미지 1/1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Screen Replacement: 9 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Screen Replacement: 9 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Screen Replacement: 9 단계, 이미지 3/3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Screen Replacement, Motherboard: 10 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Screen Replacement, Motherboard: 10 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Screen Replacement, Motherboard: 10 단계, 이미지 3/3
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Screen Replacement: 11 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Screen Replacement: 11 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Screen Replacement: 11 단계, 이미지 3/3
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Screen Replacement: 12 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement: 12 단계, 이미지 2/2
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Screen Replacement: 13 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement: 13 단계, 이미지 2/2
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Screen Replacement: 14 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement: 14 단계, 이미지 2/2
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Screen Replacement: 15 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement: 15 단계, 이미지 2/2
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Screen Replacement: 16 단계, 이미지 1/1
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Screen Replacement: 17 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Screen Replacement: 17 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Screen Replacement: 17 단계, 이미지 3/3
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
  18. Lenovo Vibe Z2 Pro Screen Replacement, Ear Piece Speaker: 18 단계, 이미지 1/2 Lenovo Vibe Z2 Pro Screen Replacement, Ear Piece Speaker: 18 단계, 이미지 2/2
    • Gently lift the speaker out of its housing by inserting the tweezers under the speaker.
  19. Lenovo Vibe Z2 Pro Screen Replacement, Charging Assembly & Headphone Jack: 19 단계, 이미지 1/1
    • Remove the 3.6 mm Phillips head screws from the charging assembly
  20. Lenovo Vibe Z2 Pro Screen Replacement: 20 단계, 이미지 1/3 Lenovo Vibe Z2 Pro Screen Replacement: 20 단계, 이미지 2/3 Lenovo Vibe Z2 Pro Screen Replacement: 20 단계, 이미지 3/3
    • Gently peel the flat cable away from the screen
    • Gently lift the charging assembly using a spudger
  21. Lenovo Vibe Z2 Pro Screen Replacement, Screen: 21 단계, 이미지 1/1
    • Your device is now ready for reassembly with the replacement screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jemma Hunter
회원 가입일: 10/04/16
215 평판
안내서 1개 작성함
USF Tampa, Team 18-3, Blackwell Fall 2016 USF Tampa, Team 18-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G3
4 회원들
안내서 12개 작성하였습니다
댓글 3개
can the glass and LCD be separated after step 21?
allen immaraj - 답글
No, it can’t. It strips te polarizing layer off the LCD and ruins it, so dont buy just the digitizer to repair. Having said that, also dont buy the LCD either as its not worth the cost as a new phone will be cheaper or similar price.
Shig Bergin - 답글
I broke my vibe z2pro screen, can anyone recommend a cheap but good display available for replacement?
Thank you!
xaosrobot - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,153
