주요 콘텐츠로 건너뛰기
Lenovo Y410P Speakers Replacement
필요한 것
  1. Lenovo Y410P Speakers Replacement, Removal of Bottom Panel: 1 단계, 이미지 2개 중 1개 Lenovo Y410P Speakers Replacement, Removal of Bottom Panel: 1 단계, 이미지 2개 중 2개
    • Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
    • Lift the bottom cover off and set it aside.
  2. Lenovo Y410P Speakers Replacement, Removal of Hard Drive: 2 단계, 이미지 2개 중 1개 Lenovo Y410P Speakers Replacement, Removal of Hard Drive: 2 단계, 이미지 2개 중 2개
    • Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Slide the hard drive out of the casing.
    • Be careful when handling the hard drive; rough impacts may cause data loss.
  3. Lenovo Y410P Speakers Replacement, Remove Optical Drive: 3 단계, 이미지 3개 중 1개 Lenovo Y410P Speakers Replacement, Remove Optical Drive: 3 단계, 이미지 3개 중 2개 Lenovo Y410P Speakers Replacement, Remove Optical Drive: 3 단계, 이미지 3개 중 3개
    • With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
    • Unscrew the three M2x3mm Phillips head screws shown.
    • At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
  4. Lenovo Y410P Speakers Replacement, Remove Keyboard and Cables: 4 단계, 이미지 2개 중 1개 Lenovo Y410P Speakers Replacement, Remove Keyboard and Cables: 4 단계, 이미지 2개 중 2개
    • Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
    • Disconnect the two WiFi antenna cables.
    • Disconnect the sound connector.
  5. Lenovo Y410P Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
    • Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
    • Be careful of the ribbon cable when removing the keyboard. The ribbon is still attached.
    • Detach the ribbon cables by opening the specified latches.
  6. Lenovo Y410P Speakers Replacement, Removal of Palm Rest: 6 단계, 이미지 3개 중 1개 Lenovo Y410P Speakers Replacement, Removal of Palm Rest: 6 단계, 이미지 3개 중 2개 Lenovo Y410P Speakers Replacement, Removal of Palm Rest: 6 단계, 이미지 3개 중 3개
    • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Turn the laptop on its side and pry the bottom from the top.
    • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
    • Remove the ribbon cable by opening its respective latch.
  7. Lenovo Y410P Speakers Replacement, Removal of Motherboard: 7 단계, 이미지 3개 중 1개 Lenovo Y410P Speakers Replacement, Removal of Motherboard: 7 단계, 이미지 3개 중 2개 Lenovo Y410P Speakers Replacement, Removal of Motherboard: 7 단계, 이미지 3개 중 3개
    • Remove the specified cable on top of the motherboard.
    • Flip the laptop over, and remove the specified cables.
    • Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
    • Remove the motherboard with hands.
  8. Lenovo Y410P Speakers Replacement, Removal of Left Speaker: 8 단계, 이미지 2개 중 1개 Lenovo Y410P Speakers Replacement, Removal of Left Speaker: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove two M2.0 x 3mm flathead screws on the left side (using the small flathead screwdriver).
  9. Lenovo Y410P Speakers Replacement, Removal of Right Speaker: 9 단계, 이미지 2개 중 1개 Lenovo Y410P Speakers Replacement, Removal of Right Speaker: 9 단계, 이미지 2개 중 2개
    • Remove two M2.0 x 3mm flathead screws on the right side (using the small flathead screwdriver).
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Eric Chen
회원 가입일: 01/22/15
868 평판
안내서 4개를 작성함
Cal Poly, Team 21-21, Maness Winter 2015 Cal Poly, Team 21-21, Maness Winter 2015 회원
CPSU-MANESS-W15S21G21
4 회원들
안내서 6개를 작성함
2가이드 댓글
Hello Sir,
May I look how the speaker for y410p looks like and what is the model for the speaker? Where can I find that parts? Thanks.
Aiman Nazri - 답글
Where can i find the speaker parts?
beslielim96 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 34
전체 시간: 3,336
