주요 콘텐츠로 건너뛰기
Lenovo Y50 Touch Speakers Replacement
필요한 것
  1. Lenovo Y50 Touch Speakers Replacement, Back: 1 단계, 이미지 1/2 Lenovo Y50 Touch Speakers Replacement, Back: 1 단계, 이미지 2/2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50 Touch Speakers Replacement: 2 단계, 이미지 1/2 Lenovo Y50 Touch Speakers Replacement: 2 단계, 이미지 2/2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50 Touch Speakers Replacement, Fan: 3 단계, 이미지 1/2 Lenovo Y50 Touch Speakers Replacement, Fan: 3 단계, 이미지 2/2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50 Touch Speakers Replacement: 4 단계, 이미지 1/3 Lenovo Y50 Touch Speakers Replacement: 4 단계, 이미지 2/3 Lenovo Y50 Touch Speakers Replacement: 4 단계, 이미지 3/3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50 Touch Speakers Replacement: 5 단계, 이미지 1/3 Lenovo Y50 Touch Speakers Replacement: 5 단계, 이미지 2/3 Lenovo Y50 Touch Speakers Replacement: 5 단계, 이미지 3/3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50 Touch Speakers Replacement: 6 단계, 이미지 1/3 Lenovo Y50 Touch Speakers Replacement: 6 단계, 이미지 2/3 Lenovo Y50 Touch Speakers Replacement: 6 단계, 이미지 3/3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50 Touch Speakers Replacement: 7 단계, 이미지 1/2 Lenovo Y50 Touch Speakers Replacement: 7 단계, 이미지 2/2
    • Lift the fan off of the laptop.
  8. Lenovo Y50 Touch Speakers Replacement, Speakers: 8 단계, 이미지 1/1
    • Locate the three speakers within the laptop.
    • The bass speaker is located near the fan's original position.
    • The side speakers are located at the upper left and right corners of the laptop.
  9. Lenovo Y50 Touch Speakers Replacement: 9 단계, 이미지 1/3 Lenovo Y50 Touch Speakers Replacement: 9 단계, 이미지 2/3 Lenovo Y50 Touch Speakers Replacement: 9 단계, 이미지 3/3
    • Using a Philips #1 screwdriver, remove the two 2.5 mm screws securing the bass speaker.
  10. Lenovo Y50 Touch Speakers Replacement: 10 단계, 이미지 1/2 Lenovo Y50 Touch Speakers Replacement: 10 단계, 이미지 2/2
    • Unplug the bass speaker from the motherboard.
  11. Lenovo Y50 Touch Speakers Replacement: 11 단계, 이미지 1/3 Lenovo Y50 Touch Speakers Replacement: 11 단계, 이미지 2/3 Lenovo Y50 Touch Speakers Replacement: 11 단계, 이미지 3/3
    • Remove the bass speaker from the laptop.
  12. Lenovo Y50 Touch Speakers Replacement: 12 단계, 이미지 1/3 Lenovo Y50 Touch Speakers Replacement: 12 단계, 이미지 2/3 Lenovo Y50 Touch Speakers Replacement: 12 단계, 이미지 3/3
    • Using a Philips #1 screwdriver, Remove the 2.5 mm screw holding each side speaker to the laptop.
  13. Lenovo Y50 Touch Speakers Replacement: 13 단계, 이미지 1/2 Lenovo Y50 Touch Speakers Replacement: 13 단계, 이미지 2/2
    • Unplug the side speakers from the motherboard.
  14. Lenovo Y50 Touch Speakers Replacement: 14 단계, 이미지 1/3 Lenovo Y50 Touch Speakers Replacement: 14 단계, 이미지 2/3 Lenovo Y50 Touch Speakers Replacement: 14 단계, 이미지 3/3
    • Remove the side speakers from the laptop.
    • The red and black wires connect to the right speaker, and the blue and white wires connect to to the left speaker.
    • The side speakers are independent from the bass speaker. It is possible to remove them without having to remove the bass speaker.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Andrew Tran
회원 가입일: 01/21/15
820 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 회원
CPSU-MANESS-W15S18G1
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 3,399
