주요 콘텐츠로 건너뛰기
Lenovo Y50-70 Touch Fan Replacement
필요한 것
  1. Lenovo Y50-70 Touch Fan Replacement, Back: 1 단계, 이미지 1/2 Lenovo Y50-70 Touch Fan Replacement, Back: 1 단계, 이미지 2/2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: 2 단계, 이미지 1/2 Lenovo Y50-70 Touch Fan Replacement: 2 단계, 이미지 2/2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: 3 단계, 이미지 1/2 Lenovo Y50-70 Touch Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: 4 단계, 이미지 1/3 Lenovo Y50-70 Touch Fan Replacement: 4 단계, 이미지 2/3 Lenovo Y50-70 Touch Fan Replacement: 4 단계, 이미지 3/3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: 5 단계, 이미지 1/3 Lenovo Y50-70 Touch Fan Replacement: 5 단계, 이미지 2/3 Lenovo Y50-70 Touch Fan Replacement: 5 단계, 이미지 3/3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: 6 단계, 이미지 1/3 Lenovo Y50-70 Touch Fan Replacement: 6 단계, 이미지 2/3 Lenovo Y50-70 Touch Fan Replacement: 6 단계, 이미지 3/3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: 7 단계, 이미지 1/2 Lenovo Y50-70 Touch Fan Replacement: 7 단계, 이미지 2/2
    • Lift the fan off of the laptop.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Vivian
회원 가입일: 01/21/15
351 평판
안내서 1개 작성함
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 회원
CPSU-MANESS-W15S18G1
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 9,349
