주요 콘텐츠로 건너뛰기
Lenovo Y520-15IKBN Display Replacement
필요한 것
  1. Lenovo Y520-15IKBN Display Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: 2 단계, 이미지 1/2 Lenovo Y520-15IKBN Display Replacement: 2 단계, 이미지 2/2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: 3 단계, 이미지 1/1
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: 4 단계, 이미지 1/1
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: 5 단계, 이미지 1/1
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: 6 단계, 이미지 1/1
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
결론
Mark A Clement
회원 가입일: 02/15/22
97 평판
안내서 1개 작성함
Comm 260 Team 15 Comm 260 Team 15 회원
Community
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 29
전체 시간: 1,204
