주요 콘텐츠로 건너뛰기
Lenovo Y70-70 Touch Fan Replacement
필요한 것
  1. Lenovo Y70-70 Touch Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Y70-70 Touch Fan Replacement: 2 단계, 이미지 1/1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Y70-70 Touch Fan Replacement, Fan: 3 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
  4. Lenovo Y70-70 Touch Fan Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Remove the fan from the device.
결론
Trevor James
회원 가입일: 03/01/18
85 평판
안내서 1개 작성함
댓글 한 개
What kind of fan is that?
I need to know what to order for replacement.
vlastimil.beno - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 393
