주요 콘텐츠로 건너뛰기
Lenovo YOGA 730-15IKB Left Fan Replacement
필요한 것
  1. Lenovo YOGA 730-15IKB Left Fan Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Left Fan Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Left Fan Replacement: 2 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Left Fan Replacement: 2 단계, 이미지 2/2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Left Fan Replacement: 3 단계, 이미지 1/1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Left Fan Replacement, Left Fan: 4 단계, 이미지 1/1
    • When the laptop is upside down, the left fan is on the right side of the laptop near the wireless card and the SSD.
    • Remove the black and white antenna wires from the groove on the right side of the fan.
  5. Lenovo YOGA 730-15IKB Left Fan Replacement: 5 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Left Fan Replacement: 5 단계, 이미지 2/2
    • Disconnect the fan cable. Pull the wire toward the right side of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  6. Lenovo YOGA 730-15IKB Left Fan Replacement: 6 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Left Fan Replacement: 6 단계, 이미지 2/2
    • Remove two 4mm Phillips #1 screws.
  7. Lenovo YOGA 730-15IKB Left Fan Replacement: 7 단계, 이미지 1/1
    • Pull the fan up and towards the front of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Rodriguez Salinas
회원 가입일: 01/23/20
448 평판
안내서 4개 작성하였습니다
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 회원
CPSU-WHITE-W20S1G6
3 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 826
