소개
Follow this guide to replace the SSD in your Lenovo YOGA 730-15IKB. The SSD—like its older predecessor, the hard drive—is where files are stored on your computer. If your SSD is getting full, you could upgrade to a higher capacity drive for more storage space.
If your computer powers on and lights up but does not boot into an operating system (like Windows), you may need to replace a failed SSD.
It is always a good idea to make a backup of your data before removing your SSD.
필요한 것
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
다른 3명이 해당 안내서를 완성하였습니다.
