주요 콘텐츠로 건너뛰기
Lenovo YOGA 730-15IKB Speaker Replacement
필요한 것
  1. Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Speaker Replacement: 2 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Speaker Replacement: 2 단계, 이미지 2/2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Speaker Replacement: 3 단계, 이미지 1/1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: 4 단계, 이미지 1/3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: 4 단계, 이미지 2/3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Speaker Replacement: 5 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Speaker Replacement: 5 단계, 이미지 2/2
    • When the laptop is upside down, the left speaker is located on the right side of the computer.
    • Pull up on the left speaker to remove it from the chassis.
    • Do not fully remove the left speaker at this point. Notice that the left and right speakers are still connected by a wire.
  6. Lenovo YOGA 730-15IKB Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the red and black wire near the front of the laptop from underneath the hooks that hold it in place.
  7. Lenovo YOGA 730-15IKB Speaker Replacement: 7 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Speaker Replacement: 7 단계, 이미지 2/2
결론
Ellis Ruckman
회원 가입일: 01/23/20
2,545 평판
안내서 6개 작성하였습니다
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 회원
CPSU-WHITE-W20S1G6
3 회원들
안내서 27개 작성하였습니다
댓글 한 개
when the stock can arrive ?
prashantdushara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 23
전체 시간: 791
