주요 콘텐츠로 건너뛰기
Lenovo YOGA 730-15IKB Wireless Card Replacement
필요한 것
  1. Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Wireless Card Replacement: 2 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Wireless Card Replacement: 2 단계, 이미지 2/2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Wireless Card Replacement: 3 단계, 이미지 1/1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1/1
    • Remove the sticky tape from the top edge of the wireless card.
  5. Lenovo YOGA 730-15IKB Wireless Card Replacement: 5 단계, 이미지 1/3 Lenovo YOGA 730-15IKB Wireless Card Replacement: 5 단계, 이미지 2/3 Lenovo YOGA 730-15IKB Wireless Card Replacement: 5 단계, 이미지 3/3
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  6. Lenovo YOGA 730-15IKB Wireless Card Replacement: 6 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Wireless Card Replacement: 6 단계, 이미지 2/2
    • Remove one 2mm Phillips #1 screw.
  7. Lenovo YOGA 730-15IKB Wireless Card Replacement: 7 단계, 이미지 1/2 Lenovo YOGA 730-15IKB Wireless Card Replacement: 7 단계, 이미지 2/2
    • Pull the wireless card out of the socket at its resting angle.
    • Do not pull straight upward. Pull towards the hinges at the back of the laptop.
결론
Ellis Ruckman
회원 가입일: 01/23/20
2,545 평판
안내서 6개 작성하였습니다
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 회원
CPSU-WHITE-W20S1G6
3 회원들
안내서 27개 작성하였습니다
댓글 한 개
I was able to use an intel AX210NGW WiFi 6 & BT 5.3 to work perfectly - plug and play. It worked at startup. I get download speeds nearly 1,000 Mb/s on a WiFi 6 network. Well worth the upgrade.
George - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 28
전체 시간: 3,462
