주요 콘텐츠로 건너뛰기
Lenovo YOGA 730-15IWL Battery Replacement
필요한 것
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: 1 단계, 이미지 1/1
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: 2 단계, 이미지 1/1
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: 3 단계, 이미지 1/1
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Max Kletskov
회원 가입일: 04/22/20
40,307 평판
안내서 16개 작성하였습니다
iFixit iFixit 회원
Staff
139 회원들
안내서 17,546개 작성하였습니다
댓글 2개
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - 답글
Check thermal paste. May be getting hot and shutting back off.
William Mobley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 43
전체 시간: 1,410
