주요 콘텐츠로 건너뛰기
Lenovo Yoga 11e Chromebook Keyboard Replacement
필요한 것
  1. Lenovo Yoga 11e Chromebook Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Keyboard Replacement: 2 단계, 이미지 1/1
    • There are two screws that will need to be removed to access the keyboard.
  3. Lenovo Yoga 11e Chromebook Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo Yoga 11e Chromebook Keyboard Replacement: 3 단계, 이미지 2/2
    • Next, flip the laptop over and open it up. The keyboard can be easily removed by pushing it back from the front. I suggest using a jimmy tool to slip into the tiny gap to push it back.
    • Look closely at the two images you'll notice a slight gap at the bottom if you did this step correctly
  4. Lenovo Yoga 11e Chromebook Keyboard Replacement: 4 단계, 이미지 1/1
    • Pull slightly up from the keyboard but NOT all the way, the ribbon cable is still connected to the motherboard
  5. Lenovo Yoga 11e Chromebook Keyboard Replacement: 5 단계, 이미지 1/3 Lenovo Yoga 11e Chromebook Keyboard Replacement: 5 단계, 이미지 2/3 Lenovo Yoga 11e Chromebook Keyboard Replacement: 5 단계, 이미지 3/3
    • Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break
결론
Congratulations you’ve successfully removed the keyboard! To reassemble your device, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Corey Meyer
회원 가입일: 05/01/17
2,292 평판
안내서 2개 작성하였습니다
Kid fixers Kid fixers 회원
Community
172 회원들
안내서 229개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 1,929
