주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 11" 20428 Hard Drive Replacement
필요한 것
  1. Lenovo Yoga 2 11" 20428 Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/3 Lenovo Yoga 2 11" 20428 Hard Drive Replacement, Back Panel: 1 단계, 이미지 2/3 Lenovo Yoga 2 11" 20428 Hard Drive Replacement, Back Panel: 1 단계, 이미지 3/3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Hard Drive Replacement, Battery: 3 단계, 이미지 1/3 Lenovo Yoga 2 11" 20428 Hard Drive Replacement, Battery: 3 단계, 이미지 2/3 Lenovo Yoga 2 11" 20428 Hard Drive Replacement, Battery: 3 단계, 이미지 3/3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 6 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
  8. Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 8 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Lift the hard drive up, turn it over, and remove the connection.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joshua Thomas Tyler
회원 가입일: 03/18/19
687 평판
안내서 5개 작성하였습니다
University of Memphis, Team S1-G2, Kim Spring 2019 University of Memphis, Team S1-G2, Kim Spring 2019 회원
UM-KIM-S19S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Is it possible to swap out the hdd for a newer ssd?
Tavin Bauerle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 57
전체 시간: 4,807
