소개
This guide will properly show how to remove and replace the hard drive component for a Lenovo Yoga 2 11” 20428. When removing the hard drive be sure to have the laptop turned off and the battery disconnected.
필요한 것
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
다른 3명이 해당 안내서를 완성하였습니다.
