주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 11" 20428 Motherboard Replacement
필요한 것
  1. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/3 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: 1 단계, 이미지 2/3 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: 1 단계, 이미지 3/3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 2 단계, 이미지 1/1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: 3 단계, 이미지 1/3 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: 3 단계, 이미지 2/3 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: 3 단계, 이미지 3/3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 4 단계, 이미지 1/1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 5 단계, 이미지 2/2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 6 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 6 단계, 이미지 2/2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Hard Drive: 7 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
  8. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 8 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift the hard drive up, turn it over, and remove the connection.
  9. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Speaker: 9 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver to unscrew the four 1.7 mm screws.
  10. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 10 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 10 단계, 이미지 2/2
    • Carefully detach the speaker wire and remove the speaker.
  11. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Bluetooth Module: 11 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 12 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 12 단계, 이미지 2/2
    • Gently grab and remove the Bluetooth module.
  13. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Motherboard: 13 단계, 이미지 1/1
    • Using your finger nail or a thin pry tool, unlock and remove the three cables.
    • Lift the two pieces of tape. Carefully pull the cable connector back to remove it from the motherboard.
    • Use the Phillips #000 screwdriver to remove the eight 3.8mm screws.
  14. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 14 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 14 단계, 이미지 2/2
    • Gently pull the cable out of the connector.
  15. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 15 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 15 단계, 이미지 2/2
    • Lift the wide cable in the center to reveal the port for the small cable underneath.
    • Using a fingernail or a thin pry tool, lift the white bar to release the cable.
    • Remove the cable from the connector.
  16. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 16 단계, 이미지 1/1
    • Lift the tape up to separate it from the motherboard.
    • Using a fingernail or a thin pry tool, lift the connector upwards to separate from the motherboard.
  17. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 17 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 17 단계, 이미지 2/2
    • Remove the black tape covering the connector.
    • Pull straight backwards to remove the connector from the motherboard.
  18. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 18 단계, 이미지 1/1
    • Pull the cable straight backwards to remove it.
  19. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 19 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 19 단계, 이미지 2/2
  20. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 20 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 Motherboard Replacement: 20 단계, 이미지 2/2
    • Use the Phillips #000 screwdriver to remove the seven 3.6mm screws.
  21. Lenovo Yoga 2 11" 20428 Motherboard Replacement: 21 단계, 이미지 1/1
    • Lift and pull backwards to remove the motherboard.
결론
Bavly Shehata
회원 가입일: 03/30/22
181 평판
안내서 1개 작성함
IUPUI, Team 1-3, Harley Spring 2022 IUPUI, Team 1-3, Harley Spring 2022 회원
IUPUI-HARLEY-S22S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 27
전체 시간: 487
