주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 11" 20428 TouchPad Replacement
필요한 것
  1. Lenovo Yoga 2 11" 20428 TouchPad Replacement, Back Panel: 1 단계, 이미지 1/3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Back Panel: 1 단계, 이미지 2/3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Back Panel: 1 단계, 이미지 3/3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 2 단계, 이미지 1/1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 TouchPad Replacement, Battery: 3 단계, 이미지 1/3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Battery: 3 단계, 이미지 2/3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Battery: 3 단계, 이미지 3/3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 4 단계, 이미지 1/1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 5 단계, 이미지 2/2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 6 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 6 단계, 이미지 2/2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 TouchPad Replacement, TouchPad: 7 단계, 이미지 1/3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, TouchPad: 7 단계, 이미지 2/3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, TouchPad: 7 단계, 이미지 3/3
    • Remove seven 2mm Phillips head #00 screws.
  8. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 8 단계, 이미지 1/1
    • The eighth screw at the top left is covered by a piece of silver tape. Gently peel the tape back and remove the screw.
  9. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 9 단계, 이미지 1/1
    • There is a small black tab holding the cable for the touchpad in place. Flip this tab up using a nylon spudger to unlock the connector.
  10. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 10 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 10 단계, 이미지 2/2
    • There is a blue plastic tab connected to the cable. Use this to gently pull the cable directly back and out of the connection point on the touchpad. If the black tab has been unlocked this should slide out without resistance.
  11. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 11 단계, 이미지 1/2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 11 단계, 이미지 2/2
    • Carefully lift the touchpad up and out of the laptop. If it gets caught you may gently wiggle it as you lift to safely remove it.
    • Be careful not to pull on the touchpad if it gets stuck as this may damage the laptop and/or the touchpad.
결론
Joshua Thomas Tyler
회원 가입일: 03/18/19
687 평판
안내서 5개 작성하였습니다
University of Memphis, Team S1-G2, Kim Spring 2019 University of Memphis, Team S1-G2, Kim Spring 2019 회원
UM-KIM-S19S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Correction to the tools needed. The screws for the bottom panel are T5 Torx, not T4 Torx. T4 will strip the screws.
Tony Tudyk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 11
전체 시간: 531
