소개
This guide will show to how to properly remove and replace the touchpad of a Lenovo Yoga 2 11 “ with the serial number 20428.
필요한 것
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
댓글 한 개
Correction to the tools needed. The screws for the bottom panel are T5 Torx, not T4 Torx. T4 will strip the screws.
Tony Tudyk - 답글
