도구
부품
지정된 부품이 없습니다.
With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
