주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 11" Back Panel Replacement
필요한 것
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: 2 단계, 이미지 1/1
    • Carefully separate back panel from laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Peyton Leeson
회원 가입일: 10/01/15
939 평판
안내서 4개 작성하였습니다
Cal Poly, Team 4-3, Maness Fall 2015 Cal Poly, Team 4-3, Maness Fall 2015 회원
CPSU-MANESS-F15S4G3
4 회원들
안내서 5개 작성하였습니다
댓글 3개
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - 답글
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - 답글
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 4,714
