주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 11" Battery Replacement
필요한 것
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Yoga 2 11" Battery Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Once all of the wires are detached, carefully remove the battery and replace.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Abbey Hickmann
회원 가입일: 10/07/15
197 평판
안내서 1개를 작성함
Cal Poly, Team 4-3, Maness Fall 2015 Cal Poly, Team 4-3, Maness Fall 2015 회원
CPSU-MANESS-F15S4G3
4 회원들
안내서 5개를 작성함
댓글 4개
how do I remove unathorized battery error?
Manuel Durugas - 답글
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - 답글
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - 답글
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 27
전체 시간: 26,909
