소개
As time passes, a battery loses its capability to hold a single charge. This guide will aide users in removing the back panel to reach and replace the faulty battery. Remember to turn the laptop off prior to the repair.
필요한 것
With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
The wire removal is mentioned in step 6, but not shown or discussed. The black antenna wire was taped in 3 spots
다른 12명이 해당 안내서를 완성하였습니다.
댓글 4개
how do I remove unathorized battery error?
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
