주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 13" Fan Replacement
필요한 것
  1. Lenovo Yoga 2 13" Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Fan Replacement: 2 단계, 이미지 1/1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Fan Replacement, Fan: 3 단계, 이미지 1/1
    • Locate the fan near the top of the laptop.
  4. Lenovo Yoga 2 13" Fan Replacement: 4 단계, 이미지 1/1
    • Carefully unscrew three 2.381mm screws using a Phillips head screwdriver.
  5. Lenovo Yoga 2 13" Fan Replacement: 5 단계, 이미지 1/1
    • The fan is attatched to four wires and a white clip. Carefully slide the clip out of the yellow port to completely remove the fan.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Nichelle
회원 가입일: 03/11/15
1,550 평판
안내서 5개 작성하였습니다
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 회원
MARS-LAFLEN-S15S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 3개
Anyone know where I can buy a replacement fan? I'm having a hard time finding the correct model. I have a first generation Thinkpad Yoga.
Daniel Shen - 답글
where can i find a new fan for lenovo yoga 2 13
peter trevisan - 답글
where can i find a new lenovo yoga 2 13?
Han Altae-Tran - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 20
전체 시간: 14,084
