주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 13" Hinge Bracket Fix
필요한 것
  1. Lenovo Yoga 2 13" Hinge Bracket Fix, Back Panel: 1 단계, 이미지 1개 중 1개
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Hinge Bracket Fix: 2 단계, 이미지 1개 중 1개
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: 3 단계, 이미지 3개 중 1개 Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: 3 단계, 이미지 3개 중 2개 Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: 3 단계, 이미지 3개 중 3개
    • The video connector can be pulled out with the attached noose. Pull gently possibly supported by lifting the connector with a screwdriver.
    • The other connector can be pushed out on the sides with the help of a screwdriver.
  4. Lenovo Yoga 2 13" Hinge Bracket Fix, Detach hinge.: 4 단계, 이미지 2개 중 1개 Lenovo Yoga 2 13" Hinge Bracket Fix, Detach hinge.: 4 단계, 이미지 2개 중 2개
    • Unscrew three screws to detach the hinge from the body.
  5. Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: 5 단계, 이미지 3개 중 1개 Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: 5 단계, 이미지 3개 중 2개 Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: 5 단계, 이미지 3개 중 3개
    • Peel out a small plastic cover, pull out center cover and unscrew left and right cover below the display.
  6. Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: 6 단계, 이미지 3개 중 1개 Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: 6 단계, 이미지 3개 중 2개 Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: 6 단계, 이미지 3개 중 3개
    • Once the two screws are loosened, the whole display can be shifted up - don't just pull it away.
    • On reassembly, put the display and cover together slightly shifted, and then gently slide the display back into position.
  7. Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: 7 단계, 이미지 3개 중 1개 Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: 7 단계, 이미지 3개 중 2개 Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: 7 단계, 이미지 3개 중 3개
    • The hinge is attached to the lid with four screws.
    • A cable runs through each hinge, you can just pull out the small rubbery holder.
    • Loosen the screw below it to open the hinge.
  8. Lenovo Yoga 2 13" Hinge Bracket Fix, Adjustening the hinge stiffness.: 8 단계, 이미지 1개 중 1개
    • The stiffness of the hinge can be adjusted by loosening the small nuts. One eighth of a turn might be enough - you will have to repeat adjusting them until the hinge has the right stiffness.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sven Meier
회원 가입일: 05/01/16
291 평판
안내서 1개를 작성함
댓글 16개
Many thanks. Thumbs up!
Simon - 답글
Hi,
Thanks you for your guide. It is amazing but i worry that remove Display guide is not too clear and user may broken the LCD before he stiffness the hinges.
Kim Son
Kim Son Vu - 답글
Can you post the fix for how to tighten hinges for Lenovo IdeaPad Yoga 13 ?
Siva Nasanakota - 답글
what type of nuts are showing in last step? those are hexagonal nuts but with what size?
Wara - 답글
Just followed this howto on my Yoga 2 13: the size of the bolts is 4.5. I know because I only have 4 and 5 sized tools, and they didn't fit. I used pliers too, it works.
Stéphane L -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 41
전체 시간: 19,556
