주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 13" Keyboard Keys Replacement
필요한 것
  1. Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: 1 단계, 이미지 1/2 Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: 1 단계, 이미지 2/2
    • Using a flat tool, carefully jimmy the selected key until it pops out.
  2. Lenovo Yoga 2 13" Keyboard Keys Replacement: 2 단계, 이미지 1/1
    • To insert a new key, simply place and apply pressure until it snaps into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nichelle
회원 가입일: 03/11/15
1,550 평판
안내서 5개 작성하였습니다
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 회원
MARS-LAFLEN-S15S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 4개
this doesn't fix a non-working electric contact, does it?
Simon - 답글
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - 답글
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - 답글
For those who found this page in 2022, I’ll answer the old questions so you don’t have to look elsewhere.
This does not fix a non-working electrical contact, this is just for replacing the top.
Secondly no it does not break the old key if you do it carefully.
Kind Regards
Lost Yogi
Lost Yogi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 17,538
