주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 Pro Trackpad Replacement
필요한 것
  1. Lenovo Yoga 2 Pro Trackpad Replacement, Battery: 1 단계, 이미지 1/1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Trackpad Replacement: 2 단계, 이미지 1/1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Trackpad Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Trackpad Replacement: 4 단계, 이미지 1/1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Trackpad Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 2 Pro Trackpad Replacement: 5 단계, 이미지 2/2
    • Remove the battery from the computer.
  6. Lenovo Yoga 2 Pro Trackpad Replacement, Trackpad: 6 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the eight 1/8" screws surrounding the trackpad.
  7. Lenovo Yoga 2 Pro Trackpad Replacement: 7 단계, 이미지 1/1
    • Using a sharp tool such as tweezers, lift up the black cover that is on top of the ribbon cable.
  8. Lenovo Yoga 2 Pro Trackpad Replacement: 8 단계, 이미지 1/1
    • With tweezers, gently slide the ribbon cable out from under the connector.
  9. Lenovo Yoga 2 Pro Trackpad Replacement: 9 단계, 이미지 1/2 Lenovo Yoga 2 Pro Trackpad Replacement: 9 단계, 이미지 2/2
    • Lift the trackpad out of the computer.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Thomas Simko
회원 가입일: 10/01/15
2,511 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015 회원
CPSU-MANESS-F15S12G14
5 회원들
안내서 12개 작성하였습니다
댓글 3개
Where can I buy this trackpad? Mine is done.
Jorge Suarez - 답글
Same here. Where can I buy the part? I cannot even find a part number.
iwaniec - 답글
I got a lot of different options on ebay but cannot rely on them. I think we could order it from IBM FRU parts but only by email or phone at:
https://www-304.ibm.com/shop/americas/co...
FRU: 73040855
Will try tomorrow
LUIS GARZA - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 9,397
