주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 Pro Wireless Card Replacement
필요한 것
  1. Lenovo Yoga 2 Pro Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/1
    • Please ensure that the laptop is turned off before beginning.
    • Using a T5 Torx screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Wireless Card Replacement: 2 단계, 이미지 1/1
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro Wireless Card Replacement: 3 단계, 이미지 1/1
    • Locate the wireless module above the battery in the top left corner of the computer.
    • Using a spudger, disconnect the two metal connectors by popping the metal piece up from the wireless module.
  4. Lenovo Yoga 2 Pro Wireless Card Replacement: 4 단계, 이미지 1/1
    • Remove the one 1/16” screw using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Wireless Card Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 2 Pro Wireless Card Replacement: 5 단계, 이미지 2/2
    • Slide the wireless module towards the battery and lift out of the laptop.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Thomas Simko
회원 가입일: 10/01/15
2,531 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015 회원
CPSU-MANESS-F15S12G14
5 회원들
안내서 12개 작성하였습니다
댓글 2개
Be careful, there is a very restrictive Whitelist in the BIOS for potential replacements, unofficial support available via their forums;
(tl;dr - go with Intel AC 7260 - m.2 connection)
https://forums.lenovo.com/t5/Lenovo-Yoga...
Jamie Haustead - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 20
전체 시간: 11,280
