주요 콘텐츠로 건너뛰기
Lenovo Yoga 3 11 Motherboard Replacement
필요한 것
  1. Lenovo Yoga 3 11 Motherboard Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Motherboard Replacement, Battery: 2 단계, 이미지 3개 중 1개 Lenovo Yoga 3 11 Motherboard Replacement, Battery: 2 단계, 이미지 3개 중 2개 Lenovo Yoga 3 11 Motherboard Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Lenovo Yoga 3 11 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Motherboard Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Lenovo Yoga 3 11 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Lenovo Yoga 3 11 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Remove the ribbon cable from the device.
  12. Lenovo Yoga 3 11 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Lenovo Yoga 3 11 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Lenovo Yoga 3 11 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the two 2 mm Phillips #00 screws securing the wireless card (top) and the SSD (bottom).
    • Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
    • Gently lift the wireless card and SSD up and out of the device.
  13. Lenovo Yoga 3 11 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the three black 2 mm Phillips #00 screws.
    • Remove the single silver 4 mm Phillips #00 screw.
  14. Lenovo Yoga 3 11 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Gently lift the motherboard up and out of the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Chandler Morris
회원 가입일: 08/27/15
172 평판
안내서 1개를 작성함
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G3
4 회원들
안내서 11개를 작성함
1가이드 댓글
Not as difficult as I thought. I was surprised that there were no empty RAM locations. Usually on a Notebookk lliek this, there is one RAM location soldered to MB, and one empty slot for upgrade. I worked on an identical Yoga 3 pro that ran 16GB. But aht meant it was soldered at factory to one 16GB RAM setup.
Mick Thielen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 7,701
