소개
Is nothing showing on your laptop's screen? Are you looking for a solution? Then you have come to the right place! This guide will help you remove and replace your laptop's screen.
필요한 것
Use a plastic opening tool or the pointed end of a spudger to pry up the 2 rubber inserts in the bottom left and right corners of the screen.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
