주요 콘텐츠로 건너뛰기
Lenovo Yoga 3 11 Trackpad Replacement
필요한 것
  1. Lenovo Yoga 3 11 Trackpad Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Trackpad Replacement, Battery: 2 단계, 이미지 1/3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: 2 단계, 이미지 2/3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: 2 단계, 이미지 3/3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Trackpad Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Trackpad Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 3 11 Trackpad Replacement: 4 단계, 이미지 2/2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Trackpad Replacement: 5 단계, 이미지 1/1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Trackpad Replacement, Trackpad: 6 단계, 이미지 1/1
    • Remove the four 2 mm Phillips #0 securing the trackpad.
  7. Lenovo Yoga 3 11 Trackpad Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to partially remove the tape.
  8. Lenovo Yoga 3 11 Trackpad Replacement: 8 단계, 이미지 1/2 Lenovo Yoga 3 11 Trackpad Replacement: 8 단계, 이미지 2/2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
  9. Lenovo Yoga 3 11 Trackpad Replacement: 9 단계, 이미지 1/2 Lenovo Yoga 3 11 Trackpad Replacement: 9 단계, 이미지 2/2
    • Slightly push down with your thumb to pop out the trackpad.
    • The laptop must be slightly open in order for the trackpad to pop out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Slade Fernandes
회원 가입일: 08/27/15
532 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G3
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
Very brief, great illustrations. Now, I need to try it.
M T Martinez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 2,868
