소개
Use this guide to replace the wireless card in your Lenovo Yoga 3 11.
필요한 것
Remove the eleven 6 mm T5 Torx screws securing the lower case.
Gently lift the lower case up and away from the device.
Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
Remove the ribbon cable from the device.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Thanks for the useful views and explanations about what’s there, however I don’t see why the battery has to be removed at all for this procedure?
(The network card appears to be accessible without)
Pete R
Are there any H*ckintosh compatible wireless cards that can be installed in this Lenovo Yoga 3 11 laptop? Asking for a friend. ;)
