소개
If you are experiencing any problems with your laptop dying quickly when it is not plugged into an outlet, You might need to replace the battery of your laptop. The battery is what gives your laptop power when it is not plugged. The following guide will show you how to replace the battery.
필요한 것
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hello… Thanks for this guide… can u help me locate the CMOS battery on this device. Regards
