소개
If your device is overheating or gets hot quickly, it might be time replace the cooling fan.
필요한 것
Remove the two 3mm screws using the PH#0 screwdriver head.
Unscrew the three 4mm screws using PH#1 (the larger screws do not come off the are attached to the housing unit of the cooling fan).
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
