주요 콘텐츠로 건너뛰기
Lenovo Yoga 3 14 USB Port Replacement
필요한 것
  1. Lenovo Yoga 3 14 USB Port Replacement, Back Case: 1 단계, 이미지 1/1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 USB Port Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 3 14 USB Port Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 3 14 USB Port Replacement: 2 단계, 이미지 3/3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 USB Port Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 USB Port Replacement: 4 단계, 이미지 1/3 Lenovo Yoga 3 14 USB Port Replacement: 4 단계, 이미지 2/3 Lenovo Yoga 3 14 USB Port Replacement: 4 단계, 이미지 3/3
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 USB Port Replacement, USB Port: 5 단계, 이미지 1/2 Lenovo Yoga 3 14 USB Port Replacement, USB Port: 5 단계, 이미지 2/2
    • Take out the 3, 3mm screws from the left hinge using the PH0 head.
    • Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Carefully lift the hinge enough to separate it from the USB port.
  6. Lenovo Yoga 3 14 USB Port Replacement: 6 단계, 이미지 1/2 Lenovo Yoga 3 14 USB Port Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
  7. Lenovo Yoga 3 14 USB Port Replacement: 7 단계, 이미지 1/1
    • The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew Victores
회원 가입일: 09/28/16
602 평판
안내서 5개 작성하였습니다
USF Tampa, Team 3-2, Passmore Fall 2016 USF Tampa, Team 3-2, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G2
4 회원들
안내서 7개 작성하였습니다
댓글 2개
Anyone know where I can buy this part? Cannot find it anywhere…
Nicolas Petersen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 2,130
