소개
The tools needed to replace the USB Port in the Lenovo Yoga 3 Pro are T5 Torx screwdriver, PH0, and a spudger.
필요한 것
Take out the 3, 3mm screws from the left hinge using the PH0 head.
Remove the 1, 4mm screw that connects the hinge to the USB port.
Carefully lift the hinge enough to separate it from the USB port.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Anyone know where I can buy this part? Cannot find it anywhere…
