주요 콘텐츠로 건너뛰기
Lenovo Yoga 3 Pro Battery Replacement
필요한 것
  1. Lenovo Yoga 3 Pro Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Battery Replacement: 2 단계, 이미지 1/1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Battery Replacement: 3 단계, 이미지 1/1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Battery Replacement: 4 단계, 이미지 1/1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Battery Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Battery Replacement: 6 단계, 이미지 1/1
    • Carefully lift and remove the battery.
결론
다른 26명이 해당 안내서를 완성하였습니다.
Federico LopezCasildo Jr
회원 가입일: 10/08/15
1,319 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 회원
CPSU-MANESS-F15S12G17
4 회원들
안내서 15개 작성하였습니다
댓글 8개
Very good and very easy to understand
barri.smith - 답글
Your really good love watching how you take apart Samsung S5 me I want to take out my mother board
and replace it with a motherboard that recognizes Optus and also download the firmware which it cannot do right now
had it repaired stuffed the phone right up so not sure if I can do this as good as you have the tools
Raewyn Dowd - 답글
does this same process work for a lonovo yoga pro 2?
Abi Alexander - 답글
Awesome and simple! Thank you!
Hong K. Nguyen - 답글
I have changed my battery and it won't turn on. I followed all the steps and the changing light won't even light up. My laptop with the old battery was working (only when connected). Not sure what to do next?
Erika
Erika Mackintosh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 113
전체 시간: 60,380
