주요 콘텐츠로 건너뛰기
Lenovo Yoga 3 Pro SSD Replacement
필요한 것
  1. Lenovo Yoga 3 Pro SSD Replacement, Battery: 1 단계, 이미지 1/1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro SSD Replacement: 2 단계, 이미지 1/1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro SSD Replacement: 3 단계, 이미지 1/1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro SSD Replacement: 4 단계, 이미지 1/1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro SSD Replacement: 5 단계, 이미지 1/1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro SSD Replacement: 6 단계, 이미지 1/1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro SSD Replacement, SSD: 7 단계, 이미지 1/1
    • Remove the 1.5 mm screw using the Philips 00 screwdriver.
  8. Lenovo Yoga 3 Pro SSD Replacement: 8 단계, 이미지 1/2 Lenovo Yoga 3 Pro SSD Replacement: 8 단계, 이미지 2/2
    • Use the plastic opening tool to remove the hard drive/SSD.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Federico LopezCasildo Jr
회원 가입일: 10/08/15
1,319 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 회원
CPSU-MANESS-F15S12G17
4 회원들
안내서 15개 작성하였습니다
댓글 5개
Thank you. This looks much easier than I imagined that it would.
jlh105 - 답글
Why do you remove the battery? Can't you just unhook the battery cable?
tombillet - 답글
You dont have to remove the battery at all to access the SSD
Tunza -
I don't think this guide is 100% accurate, in that the Yoga 3 Pro (mine anyway) ONLY supports SATA3, and NOT NVME(PCIe), for the SSD interface.
As such, if you order, and try to install the Crucial P5 drive (after imaging the old drive to the P5), it will NOT recognize it, in the BIOS, because it can't bootstrap (or in any way, really) the drive.
Maybe there were multiple motherboards, with different chipsets, for the Yoga3 Pro, I have no idea, on this part, but I know the one we have is definitely limited, to SATA3.
@CPSU-MANESS-F15S12G17 (I hope this tags the team, I couldn't figure out how to tag Federico+LopezCasildo, directly, so I'm tagging "the team"), you might want to review this, and adjust, accordingly (there are plenty of SATA3 drives that can/will work, with this system).
pgrey - 답글
Thanks for noting this! I think you're right—I'll update the guide!
Arthur Shi -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 18
30일 전: 65
전체 시간: 22,153
