주요 콘텐츠로 건너뛰기
Lenovo Yoga 3 Pro Speakers Replacement
필요한 것
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: 2 단계, 이미지 1/1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: 4 단계, 이미지 1/1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: 5 단계, 이미지 1/1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: 6 단계, 이미지 1/1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: 7 단계, 이미지 1/1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: 8 단계, 이미지 1/2 Lenovo Yoga 3 Pro Speakers Replacement: 8 단계, 이미지 2/2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: 9 단계, 이미지 1/3 Lenovo Yoga 3 Pro Speakers Replacement: 9 단계, 이미지 2/3 Lenovo Yoga 3 Pro Speakers Replacement: 9 단계, 이미지 3/3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: 10 단계, 이미지 1/2 Lenovo Yoga 3 Pro Speakers Replacement: 10 단계, 이미지 2/2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: 11 단계, 이미지 1/2 Lenovo Yoga 3 Pro Speakers Replacement: 11 단계, 이미지 2/2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Caroline Seifert
회원 가입일: 10/01/15
538 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 회원
CPSU-MANESS-F15S12G17
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 2,709
