주요 콘텐츠로 건너뛰기
Lenovo Yoga 3 Pro USB Ports Replacement
필요한 것
  1. Lenovo Yoga 3 Pro USB Ports Replacement, Battery: 1 단계, 이미지 1/1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro USB Ports Replacement: 2 단계, 이미지 1/1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro USB Ports Replacement: 3 단계, 이미지 1/1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro USB Ports Replacement: 4 단계, 이미지 1/1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro USB Ports Replacement: 5 단계, 이미지 1/1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro USB Ports Replacement: 6 단계, 이미지 1/1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro USB Ports Replacement, Speakers: 7 단계, 이미지 1/1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro USB Ports Replacement: 8 단계, 이미지 1/2 Lenovo Yoga 3 Pro USB Ports Replacement: 8 단계, 이미지 2/2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro USB Ports Replacement: 9 단계, 이미지 1/3 Lenovo Yoga 3 Pro USB Ports Replacement: 9 단계, 이미지 2/3 Lenovo Yoga 3 Pro USB Ports Replacement: 9 단계, 이미지 3/3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro USB Ports Replacement: 10 단계, 이미지 1/2 Lenovo Yoga 3 Pro USB Ports Replacement: 10 단계, 이미지 2/2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro USB Ports Replacement: 11 단계, 이미지 1/2 Lenovo Yoga 3 Pro USB Ports Replacement: 11 단계, 이미지 2/2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
  12. Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: 12 단계, 이미지 1/2 Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: 12 단계, 이미지 2/2
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
  13. Lenovo Yoga 3 Pro USB Ports Replacement: 13 단계, 이미지 1/1
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
  14. Lenovo Yoga 3 Pro USB Ports Replacement: 14 단계, 이미지 1/1
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
  15. Lenovo Yoga 3 Pro USB Ports Replacement: 15 단계, 이미지 1/1
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
  16. Lenovo Yoga 3 Pro USB Ports Replacement: 16 단계, 이미지 1/1
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
  17. Lenovo Yoga 3 Pro USB Ports Replacement: 17 단계, 이미지 1/1
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
  18. Lenovo Yoga 3 Pro USB Ports Replacement: 18 단계, 이미지 1/1
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
  19. Lenovo Yoga 3 Pro USB Ports Replacement: 19 단계, 이미지 1/1
    • Remove the USB assembly using the plastic opening tool.
  20. Lenovo Yoga 3 Pro USB Ports Replacement: 20 단계, 이미지 1/1
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
  21. Lenovo Yoga 3 Pro USB Ports Replacement: 21 단계, 이미지 1/1
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Caroline Seifert
회원 가입일: 10/01/15
538 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 회원
CPSU-MANESS-F15S12G17
4 회원들
안내서 15개 작성하였습니다
댓글 4개
Repaired customers Yoga 3 that had NO working USB ports whatsoever in less than an hour - after cleaning & replacing (no parts needed)
All USB ports were fully functional once again...
Great job & thank you for the help :)
admin - 답글
This guide helped me quite a bit today. I really appreciate you providing it.
Jon Tucich - 답글
Can you please help with information on where to get the DC input USB port part. My USB port is broken and unable to find it
Dheeraj - 답글
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
ori elyada - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 54
전체 시간: 13,220
