주요 콘텐츠로 건너뛰기
Lenovo Yoga 700-11ISK Battery Replacement
필요한 것
  1. Lenovo Yoga 700-11ISK Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Yoga 700-11ISK Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Battery Replacement: 2 단계, 이미지 1/1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Battery Replacement: 4 단계, 이미지 1/1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Sean Wong
회원 가입일: 10/06/16
859 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G6
4 회원들
안내서 7개 작성하였습니다
댓글 3개
Hey
I own lenovo yoga 700 14 inch, it has a motherboard 5b20k41654. For some reason two of mother board ics burnt out
I have got the number of one IC but failed to find the number/code of other. (the IC I am looking for resides near left side of ram slot)
Please let me know if someone can help me finding the right IC or Schematic of yoga 700 motherboard
I'll be very great full
Thanks
muhammad bilal - 답글
Why do you recommend buying a T7 Torx Screwdriver? I bought it, then re-read your tutorial after I couldn't unscrew the screws, where you said it should be a T5 Torx Screwdriver...
Eric Macaluso - 답글
Charging point break not display
Lenovo laptop notebook 6 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 23
전체 시간: 8,511
