소개
If you are having troubles with your Lenovo's monitor screen or know that you have broken it, you may need to replace your LCD or screen.
필요한 것
Flip your device so that the bottom panel is facing up.
Remove the eleven 5mm Torx T5 screws from the back panel.
Use a spudger to unclip clips on the front and near the USB ports on each side
Lift the back panel off
Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
Carefully remove the battery from the laptop.
Remove the base from the LCD by lifting it upwards.
Flip the LCD so that the hinges face you and the screen faces upwards.
Remove the two LCD bezel screw pads located in the bottom left and right outer corners by pulling them up and out.
Remove the two 4.4 mm Phillips #1 screws located under the screw pads.
Pry the two side hinge covers with a plastic spudger and pull them up and away from the LCD.
다른 7명이 해당 안내서를 완성하였습니다.
Your list of t7 screwdriver costed me to order a wrong one.
it should be T5 but the ad listed T7!!!!!
it is frustrating.
Remy Williams - 답글
Mine had T5 as well.
alan - 답글
