주요 콘텐츠로 건너뛰기
Lenovo Yoga 700-11ISK Power Port Replacement
필요한 것
  1. Lenovo Yoga 700-11ISK Power Port Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Yoga 700-11ISK Power Port Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Power Port Replacement: 2 단계, 이미지 1/1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Power Port Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Power Port Replacement: 4 단계, 이미지 1/1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Power Port Replacement, Power Port: 5 단계, 이미지 1/2 Lenovo Yoga 700-11ISK Power Port Replacement, Power Port: 5 단계, 이미지 2/2
    • Remove the following screws holding both the right LCD hinge and the power port to the laptop:
    • Four 5mm Phillips #1 screws.
    • One 3mm Phillips #1 screw.
    • Gently pull the hinge up and away from the laptop.
  6. Lenovo Yoga 700-11ISK Power Port Replacement: 6 단계, 이미지 1/3 Lenovo Yoga 700-11ISK Power Port Replacement: 6 단계, 이미지 2/3 Lenovo Yoga 700-11ISK Power Port Replacement: 6 단계, 이미지 3/3
    • Carefully slide bundle cable connector out from its connector on the motherboard.
    • Pull the ends of the black connector containing the wires to avoid damage to the wires.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Emma Morley
회원 가입일: 10/23/16
378 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G6
4 회원들
안내서 7개 작성하였습니다
댓글 2개
Hey
I own lenovo yoga 700 14 inch, it has a motherboard 5b20k41654. For some reason two of mother board ics burnt out
I have got the number of one IC but failed to find the number/code of other. (the IC I am looking for resides near left side of ram slot)
Please let me know if someone can help me finding the right IC or Schematic of yoga 700 motherboard
I'll be very great full
Thanks
muhammad bilal - 답글
If you’re replacing the power port where is the part? How do I find the power port to replace? Which part is it?
atom_burke - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 29
전체 시간: 5,524
