주요 콘텐츠로 건너뛰기
Lenovo Yoga 700-11ISK Solid State Drive Replacement
필요한 것
  1. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Yoga 700-11ISK Solid State Drive Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Solid State Drive Replacement: 2 단계, 이미지 1/1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Solid State Drive Replacement: 4 단계, 이미지 1/1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 1/1
    • Remove the one 2mm Phillips #1 screw holding the hard drive to the laptop.
  6. Lenovo Yoga 700-11ISK Solid State Drive Replacement: 6 단계, 이미지 1/1
    • Pull the solid state disk out of the connector and lift it out of the laptop.
    • Make sure the hard drive is oriented correctly with the label facing up before re-inserting.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Emma Morley
회원 가입일: 10/23/16
378 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G6
4 회원들
안내서 7개 작성하였습니다
댓글 3개
How to transfer the windows os to the newly install Crucial ssd?
Bernardino Santiago - 답글
how to transfer the windows OS to the newly install ssd?
Specification for the M.2 SSD: Make sure it’s a Type 2280 (22mm x 80mm) SATA M.2 with B and M key edge connector, not the B key used on NvMe M.2 for PCIe. It’s easy to confuse the two when ordering online.
Joe Rhio - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 9
전체 시간: 5,180
