주요 콘텐츠로 건너뛰기
Lenovo Yoga 700-11ISK Touchpad Replacement
필요한 것
  1. Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Touchpad Replacement: 2 단계, 이미지 1/1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Touchpad Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Touchpad Replacement: 4 단계, 이미지 1/1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: 5 단계, 이미지 1/3 Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: 5 단계, 이미지 2/3 Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: 5 단계, 이미지 3/3
    • Remove the four 4mm Phillips #1 screws holding the touchpad onto the laptop.
    • Use a spudger to lift up the two black tabs on the ZIF connectors and then pull the cable out by the blue tab.
    • The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  6. Lenovo Yoga 700-11ISK Touchpad Replacement: 6 단계, 이미지 1/1
    • Slightly separate the two halves of the laptop with one hand and slide the touchpad out from the laptop with the other.
    • There may be silver tape holding the touchpad to the laptop. You do not need to replace the tape when reassembling the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sean Wong
회원 가입일: 10/06/16
859 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G6
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
The “Tools Required” section says “Torx T7” but Step 1 lists, and (more importantly) the actual device has Torx T5 screws.
Step 5 suggests using a spudger, so perhaps that should be listed too.
alan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 2,193
