소개
The back panel protects the inside of your device from damage. If your back panel is broken, use this guide to replace it. Only remove this if your trying to replace something on the inside or the back panel itself.
Make sure back panel is facing up.
Remove eleven 5mm screws with the T5 Torx Screwdriver.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
