주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-11ISK Motherboard Replacement
필요한 것
  1. Lenovo Yoga 710-11ISK Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the eleven screws that attach the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Motherboard Replacement: 2 단계, 이미지 1/1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Motherboard Replacement: 3 단계, 이미지 1/2 Lenovo Yoga 710-11ISK Motherboard Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Hold the cable connector on both sides and gently pull it directly out of its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Motherboard Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 710-11ISK Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the eight screws securing the motherboard, Wi-Fi card, and SSD card.
    • Unplug the Wi-Fi and SSD cards from the motherboard along with the attached wire harnesses.
  5. Lenovo Yoga 710-11ISK Motherboard Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 710-11ISK Motherboard Replacement: 5 단계, 이미지 2/2
    • Lift the motherboard up and out.
결론
Jarrett Stoll
회원 가입일: 02/10/22
385 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 174
